Activity › Forums › Media 100 › Is it possible to change logged clips specs?
  • Is it possible to change logged clips specs?
    Posted by Dankelly on April 18, 2005 at 2:48 am
    After logged many clips with only video to batch dig. found out it was suposed to dig. audio too. Is it possible to change my logged clips or will i have to re-log EVERYTHING w/ audio tracks enable??
    working on OS 9.22, m100 7.5.
    Thanx in advance!
    Dan
    Dankelly replied 21 years, 5 months ago 3 Members · 4 Replies
  • Jim Calahan
    April 18, 2005 at 2:06 pm
    Export to powerlog do a find and replace on your VA1A2 and import it back in.
    Jim Calahan
    KVIE, Sacramento
  • Dankelly
    April 20, 2005 at 12:00 am
    thanx for your response… but i just cant find where to export a Powerlog, only an EDL. (i only see Powerlog on the import menu box), but fine, the edl worked ok, there was only one more prob.: i can only export it from my time line, and importing it back creates a new time line….. is it possible to do the same from and back to a bin???
    thanx in adv
    Dan Kelly
  • Floh Peters
    April 20, 2005 at 7:07 am
    Hi Dan,
    the ability to change clip parts and to export a PowerLog has been added in V8.x versions. If you want you can send me the Bin, I will make the changes and then export it as a PowerLog that you can reimport. Or you can download the SW only version of Media 100 and do it for yourself,
  • Dankelly
    April 20, 2005 at 12:28 pm
    Hi Floh,
    Thanx a lot for the info and help, but we had to send already an offline copy to the client this morning, so i just ended up reloggging the whole thing…… but it good to know there is a way to solve it next time (well, hopefully there wont have next time! 8)
    again
    THANX ALOT!
    Dan
