Activity Forums Apple Final Cut Pro Legacy Is it possible to capture Quicktime movies?
  • Is it possible to capture Quicktime movies?
    Posted by Joseph Valver on June 23, 2008 at 1:02 am
    To anyone that can answer this question,
    Is there anyway I can capture an existing quicktime movie from either a dvd or external hard-drive rather than importing them? Because importing them forces me to continually render and rerender the clips when i put them in or edit them in my sequence.
    Thanks Joe V…
    Jimmy Spangler replied 18 years, 2 months ago 4 Members · 3 Replies
  • Walter Biscardi
    June 23, 2008 at 2:44 am
    [joseph valver] “Because importing them forces me to continually render and rerender the clips when i put them in or edit them in my sequence.”
    That’s because your Sequence Settings don’t match your Clip Settings. Fix this and you’ll edit in realtime with no rendering.
    https://library.creativecow.net/articles/biscardi_walter/realtime_sequences.php
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Colin Mcquillan
    June 23, 2008 at 2:47 am
    Convert the original Quicktime files to the same codec/fps/… as your sequence.
    Then import the resulting file into FCP and you wont have to render any more.
    you can open the file in quicktime player and choose Export, setting the properties to match your sequence. or you can do this with Compressor, MPEG streamclip,, what ever.
    Colin McQuillan
    Van. B.C.
  • Jimmy Spangler
    June 23, 2008 at 5:08 am
    Batch Export works well for me as long as you aren’t going from 29.97 to 23.98 because in that case it won’t always remove the 3:2 Pulldown correctly.
    Batch Export works well because it gives all the capture setting options to transcode with.
