Activity Forums Adobe After Effects Is it possible to animate between two paths?
  • Is it possible to animate between two paths?
    Posted by Vinh Ton on September 3, 2013 at 1:02 am
    *Goal: effect of text spinning in to tornado
    *Trying: animate text along path
    -mask 1 is an open path where the text going in to the tornado
    -mask 2 is a closed path where the text revolves in a loop
    Is this possible? Specifically I can switch the path mask from 1 to 2 at a point in time?
    The alternative is to only have 1 path and repeat the loop at the end. The challenge with this is find the exact position to loop so it does not appear the animation is cutting out
    Vinh Ton replied 13 years ago 2 Members · 2 Replies
  • Daniel Peterson
    September 3, 2013 at 1:01 pm
    One alternative you could try is to use the Distort>Twirl effect… have the text travel along the path then animate the twirl at the appropriate time.
    Filmmaker | Motion Graphic Artist
    http://www.saltmedia.net
    http://www.TheDigitalSlice.com (beta)
    Seeking clarity in digital post production. Help us gather some data!
  • Vinh Ton
    September 3, 2013 at 1:16 pm
    Thanks, I’ll try.
