Activity › Forums › Adobe After Effects › Is it possible to add time to the BEGINNING of a timeline?
  • Is it possible to add time to the BEGINNING of a timeline?
    Posted by Daniel Haskett on May 3, 2005 at 1:10 am
    hi there,
    Was just wondering, you know when you make a composition longer by say 10 seconds, it always adds it to the end of the composition, is there anyway of making it add time to the front of the composition?
    Dan
    Steve Dillon replied 6 years, 9 months ago 3 Members · 2 Replies
  • Yoondo
    May 3, 2005 at 5:38 am
    I don’t think you can add time to the beginning of the timeline. Even if you were able to,
    then it will have to be in minus. So the bottom line is add time to the end of timeline
    and select your layer(s) and move them over accordingly.
  • Steve Dillon
    January 2, 2020 at 4:37 pm
    You can add time to the composition, then select all layers and use Alt + Shift + Page Down to move all layers 10 frames down the timeline at once.
    https://www.schoolofmotion.com/blog/after-effects-timeline-shortcuts
