Activity Forums Apple Final Cut Pro Legacy Is it possible to add more than 1 transition at a time?
  • Is it possible to add more than 1 transition at a time?
    Posted by Carlos Castro on February 4, 2008 at 3:10 pm
    Lets say you have a narration track and you what to clean up some potential pops or clips. I normally place a 6-10 frame audio dissolve centered between edits to soften them up.
    Instead of doing them 1 by 1, is their a way on FCP to mark an in, and an out point, highlight the track and then dissolve all the edits between both points?
    Carlos Castro replied 18 years, 7 months ago 2 Members · 2 Replies
  • Kevin Monahan
    February 4, 2008 at 7:02 pm
    You can do that, but not how you think.
    Set the 2 fr. fade your Default Audio Transition, select all the audio clips in the timeline, then drag them back into the Canvas on the Overwrite with Transition overlay. Your audio clips will then have the proper cross fade on all the selected clips.
    Makes sense?
  • Carlos Castro
    February 4, 2008 at 10:23 pm
    Thanks Kevin, I’ll try that.
