Activity › Forums › Maxon Cinema 4D › is it possible to achieve this in Cinema 4D
  • Michael Munkittrick
    March 28, 2007 at 1:33 am
    It can be simulated to a degree within Cinema4D, but to get a far more realistic result, you’re going to need RealFlow or some very, very complex particle effect algorithms. I can’t recall exactly where I saw the tutorial, but I believe that it was at http://www.mograph.net, however there was a way to use metaballs and the advanced renderer in conjunction with Pyrocluster and displacement maps. I also seem to recall that each frame was about a 3 hour render on a dual Xeon 3.6 GHz with a lot of RAM.
    Good luck with it,
    Michael Munkittrick
    Gainesville, Florida USA
