Activity Forums Adobe After Effects Is it normal Fractal Noise don’t work on 16bpc ?
  • Is it normal Fractal Noise don’t work on 16bpc ?
    Posted by Foucault Martial on February 9, 2008 at 1:31 pm
    Hi to all,
    Why when I try to change the “Fractal Type” to “Turbulent (Smooth, Basic or Sharp)” on a 16bpc or 32bpc composition the layer become plein white.
    If I change the coposition to 8bpc the Fractal Noise whith this Fractal Type is shown.
    The Turbulence Type is the only whose done this.
    The result, a beautiful visible Banding.
    Any solution ?
    Thanks a lot
    Why not ? Pourquoi pas?
    Win XP SP2
    AE CS3
    Darby Edelen replied 18 years, 7 months ago 3 Members · 3 Replies
  • Richard Harrington
    February 9, 2008 at 5:47 pm
    Open the effect palette and look at the icons… it will tell you which are 16 bpc
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Foucault Martial
    February 9, 2008 at 6:09 pm
    Fot the Fractal Noise nothing is write to explain it’s 8bpc, 16bpc or 32bpc
    Win XP SP2
    AE CS3
  • Darby Edelen
    February 9, 2008 at 7:36 pm
    Have you tried lowering the brightness value of the Fractal Noise after you change the Fractal Type? Different fractal types will be either lighter or darker even with the same Contrast/Brightness settings, so you usually need to change these if you change the type.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
