Activity Forums Apple Final Cut Pro Legacy Is it better to work in upper field dominance or lower field dominance….
  • Is it better to work in upper field dominance or lower field dominance….
    Posted by Jennifer on April 14, 2005 at 8:21 pm
    Or does it depend on the format of the video I bring in? Right now I have it set in lower. Thank you in advance for your help!
    Jennifer replied 21 years, 4 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 14, 2005 at 8:39 pm
    If you haven’t noticed that things look wrong, you’re fine.
    DV is always lower field first.
    If your field dominance is reversed, moving objects will appear jittery.
    Regards,
    Walter Soyka
  • Jennifer
    April 14, 2005 at 8:59 pm
    Why, thank you!
