Activity › Forums › VEGAS Pro › Is it better to render & capture offline or online?
  • Is it better to render & capture offline or online?
    Posted by Carson Young on February 5, 2007 at 10:01 pm
    Just a question I had if anyone has any advice on the subject.
    Thanx,
    Carson
    Carson Young replied 19 years, 7 months ago 4 Members · 5 Replies
  • Gary Kleiner
    February 5, 2007 at 10:09 pm
    Perhaps you can explain what you mean. In Vegas the usual meaning of these terms does not come into play unless you are talking about use of proxies for unsupported formats.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Carson Young
    February 5, 2007 at 10:19 pm
    I guess what i’m trying to ask is, if having the internet running in the background takes up any additional processor power or RAM. If i were to render a project offline would it perhaps render a little faster, i guess is my question.
  • Mike Kujbida
    February 6, 2007 at 3:54 am
    Carson, the short answer is to make sure NOTHING is running that shouldn’t be running during a render. That includes being connected to the net.
    I read on one Vegas forum a while back about one user who never bothered to disconnect during a render.
    Unfortunately he also had Windows update set to automatic.
    You can guess what happened.
    Near the end of a long render a render, Windows decided it needed an update so it did – automatically. By the time the guy realized what was happening, the update had installed and, as usual, the computer re-booted and he lost his render 🙁
    Here, from Sony, is the LONG answer. While some of is may not be applicable, the list of services is. HTH.
    Answer ID 1101
    My program will not start.
    Question
    The program will not start up.
    Answer
    First, find what is running in the background. Press Ctrl+Alt+Del at the same time and you will see a list of the programs currently running (some users will have to hit the “Task Manager” button). Move over to the Processes Tab and click the “Image Name” heading at the top left of this window , you would be able to view these items by alphabetical order by user/system. Once all these items are arranged, look under the User Name column for items that are listed as belonging to your User Account.
    You only need to leave running the following;
    For Windows XP:
    explorer.exe
    taskmgr.exe
    Under the User Name “SYSTEM”
    System Idle Process
    System
    smss.exe
    csrss.exe
    winlogon.exe
    services.exe
    lsass.exe
    svchost.exe
    spoolsv.exe
    For Windows 2000:
    explorer.exe
    LSASS.EXE
    mspmspsv.exe
    mstask.exe
    SERVICES.EXE
    SMSS.EXE
    SPOOLSV.EXE
    stisvc.exe
    svchost.exe
    System
    System Idle Process
    taskmgr.exe
    WINLOGON.EXE
    WinMgmt.exe
    Windows 9x and ME:
    You would only need two of these items to keep your computer up and running. These would be Explorer and Systray. You could End Task on everything else in this list. Some things may be stubborn, and you may have to close out of them two or three times before you are able to get rid of it. ***Be careful when you are closing out of these tasks that you DO NOT press Ctrl+Alt+Del two times in a row as it would cause your system to Restart and start this process over.
    After doing so, here are a few other steps to try:
    Do you have any Anti-Virus Software on your computer? Make sure you update this software from the manufacturer, then run a full system scan. If you do not have any Anti Virus Protection, it is suggested to either purchase or download a copy and install it onto your system as a preventive maintenance.
    When was the last time you had updated your Computer’s Drivers from the Manufacturer’s Web Site? You would be able search for any newer, updated Motherboard, Sound Card, and Video Card drivers. Also check for any Peripherals that would be installed (i.e. Printers, Scanners, Card Readers). If you have an outdated or improper driver loaded, you may not be using that device correctly and it could potentially be causing problems.
    Lower your hardware graphics acceleration. Go to your Control Panel–>Display–>Settings–>Advanced–>Troubleshooting tab to do this.
    Disconnect all USB and firewire devices from the system, along with all dongles.
    Change the mouse.
    Install the latest version of DirectX, located here.
    Un-Install the software using the Add/Remove Programs utility in the control panel, then Re-Install from the latest update available here.
    (Note: If there is not an update available for the product, you may still want to try the uninstall and reinstall from the same installer/CD that you installed from initially.)
  • Charles Avanti
    February 6, 2007 at 5:40 pm
    This gives a whole new meaning to the term
  • Carson Young
    February 6, 2007 at 8:39 pm
    Awesome information Mike, thanx a lot for your time!
