Activity › Forums › Adobe Premiere Pro › Is it Best to Use 1 Hard Drive or 2 Hard Drives with PP and AE?
Posted by John Kompa on August 24, 2006 at 4:20 pmOkay, my hard drive just crapped out so it’s time to upgrade. I previously had a single 200G hard drive with only 1 partition on it that had Windows XP, all my software, games, media, etc.
Is it best for me to buy 2 new hard drives…one to install Windows and my software while using the other drive for scratch files, media such as photos and videos, etc? Thoughts?
john ‘rekless’ kompaBlast1 replied 20 years ago 5 Members · 11 Replies -
Vincent Becquiot
August 24, 2006 at 6:10 pmJohn,
It is actually best to have 3. One for the OS, one for your captured media, and one for your rendering/cache; but definitely a minimum of 2.
Vince
Vince Beck
Santa Rosa, CA -
Ulflaursen
August 24, 2006 at 6:38 pmWill the third drive increase speed?
If I have a systemdrive, WD Raptor 10k drive, and 320 GB (raid 0 on two 160 GB disks) and a single drive as third, what should go on the raid set and what on the third drive?
/Ulf
Rgds.
/Ulf – Denmark -
Vincent Becquiot
August 24, 2006 at 6:50 pmThe point here is to separate anything Premiere will want to pull at the same time, keeping a single drive having to go back and forth looking for stuff.
How much speed you will gain from a third drive is of course depending on the overhaul system, and whether it can keep up with the data coming through.
Vince
Vince Beck
Santa Rosa, CA -
Vincent Becquiot
August 24, 2006 at 6:55 pmRegarding what should go where. I’ ll be honest here, I can’t confirm this, but I can safely assume that the OS should use the fastest drive. Of course anything to do with video will want to have the largest drive so that the system doesn’t have to start splitting things up too much once you start running low in space.
My two bit 😉
Vince
Vince Beck
Santa Rosa, CA -
Blast1
August 24, 2006 at 9:25 pm[Vincent Becquiot] “but I can safely assume that the OS should use the fastest drive”
Alot of people waste money on very fast large drives for the OS/Apps, but once booted and program is loaded there is very little use for the OS drive except housekeeping, usually a good use for a newer PATA drive thats laying around or been in use in a system thats being upgraded, use a single or raid SATA II for capture and video source files, another SATA drive for scratch disks, previews, audio, finished clips
Vincent Becquiot
August 24, 2006 at 10:44 pmAll I can tell you is that back when I added that third drive and imaged copy my OS to the newest/fastest drive, I shaved an average of 20% of most of my renders, and lost some of the freezes I was getting while editing a timeline that was fully rendered. And if you happen to work with 1080i footage, you will agree that any little system improvement will make a huge difference. BTW, This was without a fresh install, and no other added components.
Vince
Vince Beck
Santa Rosa, CA -
Ulflaursen
August 25, 2006 at 5:33 amThanks Blast1 and Vincent.
I have a lot to go for now – need to go shopping 🙂
/Ulf
Rgds.
/Ulf – Denmark -
Blast1
August 25, 2006 at 10:22 am[Vincent Becquiot] “I shaved an average of 20% of most of my renders, and lost some of the freezes I was getting while editing a timeline that was fully rendered”
Premiere sets up stuff on the system drive that can affect your overall system performance if you don’t move them off to another drive, one indication is random hangups because of fighting with housekeeping tasks. -
Vince Becquiot
August 25, 2006 at 8:44 pmYes, and that reminds me, someone told me once that it is better to actually install the Premiere files, which usually go in “Program files” on another drive than the operating system’s . Not sure if there is any truth to that, but it might be worth giving it a shot.
Vince
John Kompa
August 26, 2006 at 1:11 pmVincent Becquiot Yes, and that reminds me, someone told me once that it is better to actually install the Premiere files, which usually go in “Program files” on another drive than the operating system’s . Not sure if there is any truth to that, but it might be worth giving it a shot.
Hmm. That’s interesting comment. I’d like to hear from others if they agree. I’m going to purchase a couple of drives SOON…
John K
