Activity Forums VEGAS Pro Is it a DVD rendering bug?
  • Is it a DVD rendering bug?
    Posted by Will Brown on February 28, 2011 at 12:43 pm
    Hi guys,
    I think I have found a bug in Vegas Pro 9.
    Rendering a clip with only 2 layers, 1 standard clip with added Chroma Key and the bottom layer is a picture.
    When rendering to MPEG2 DVD, using ‘Best’ the picture layer is not rendering, when using ‘Preview’ all is ok.
    When rendering using MPEG HD or pretty much anything else, all is ok.
    Update:
    After rendering in Preview, I tried again on Best and it works fine!
    Nightmare.
    Will.
    Vegas Pro 9.
    http://www.willbrownltd.co.uk
    John Rofrano replied 15 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    February 28, 2011 at 2:00 pm
    [Will Brown] “After rendering in Preview, I tried again on Best and it works fine!”
    Ghost in the machine? 😉
    Usually there is no reason to use Best mode unless you are resizing the output. Good is the default because it is usually good enough for most work.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
