Is IO compatible with FCP5
From what I can see at the FinalCut site, the answer is yes. But if you take a good look, you will see that this page (https://www.apple.com/finalcutstudio/finalcutpro/specs.html) has not changed much since FCP 4.5 and some of it’s parts are the same (like link to Final Cut Pro HD Device Qualification PDF file, https://www.apple.com/finalcutstudio/finalcutpro/qualification.html).
Now, can anyone give us official info on this question?
I would like to take my place in the line to buy Tiger/QT7/FCP5 but not if IO will not work with this combo.
Thank you in advance,
Jadranko
