Activity Forums Adobe After Effects Is interpolated rotoscoping possible?
  • Is interpolated rotoscoping possible?
    Posted by Grayson Earle on December 5, 2009 at 10:41 pm
    Hello,
    I’ve been doing some research on Wacom tabs, animation, etc. and messing around with Flash. As far as I can tell, no tweening option will allow for a good interpolation of keyframes to achieve the Scanner Darkly (or anything like that) effect. I know that the film makers have a proprietary software that does this for them, is it possible without their software? All the examples I have seen have been frame by frame! Someone told me that with After Effects you can do this, but I haven’t been able to locate such a tutorial.
    Me
    Revolt
    Todd Kopriva replied 16 years, 9 months ago 2 Members · 1 Reply
  • Todd Kopriva
    December 5, 2009 at 11:03 pm
    Yes, After Effects will interpolate mask shapes between keyframes that you set.
    I recommend starting on this page and checking out the resources that it links to:
    “Rotoscoping introduction and resources”
    But your question isn’t just about rotoscoping. You are talking about achieving a specific look. Don’t get confused and think that the A-Scanner-Darkly result is synonymous with rotoscoping.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
