Activity › Forums › Blackmagic Design › Is Hyperdeck Shuttle capable of recording Op Atom DNXHD files?
Scott Davis replied 14 years, 8 months ago 5 Members · 11 Replies
Scott Davis
January 19, 2012 at 1:11 pmIf they are Op Atom MXF file: Look in your “Avid Media” folder and see what the largest numbered folder is in the “MXF” folder. Create a new folder in that directory with a number; one larger. Drop your files from the Hyperdeck into that folder. Once they are done copying over, launch Avid. It will scan the media folder and create a new database. Once that is done create a new bin in Avid. Go to the folder you created and copied over your Hyperdeck media to and drag the file labeled “msmMMOB into the Avid bin. Your bin should populate with your clips. Seems complicated but once you do it; it is very simple and fast.
