Activity Forums Apple Final Cut Pro Legacy Is HDV A-OK?
  • Posted by Martin Nelson on September 29, 2010 at 5:31 pm
    I’m about to cut a small project with footage that was shot and ingested HDV 1080i60. Is this a safe format for FCP or should I convert it to a ProREz codec? If so, what would be the most suitable match?
    Martin
    2 x 2.26 Ghz Quad-Core Intel Xeon
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
    Avid Media Composer 4.0.2.20
    Martin Nelson replied 15 years, 11 months ago 5 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    September 29, 2010 at 5:56 pm
    If you have the space, capture and edit ProRes. If not, then capture HDV, but use a ProRes timeline. Anything you can do to avoid editing in a GOP formatted timeline.
    https://lfhd.net/2009/03/18/in-hdv-hell/
    https://lfhd.net/2010/09/24/hdv-hell-the-second-coming/
    Shane
  • Mark Spano
    September 29, 2010 at 6:07 pm
    Shane is right. Take heed!
    That is all.
  • Martin Nelson
    September 29, 2010 at 9:30 pm
    Thanks Shane,
    Very interesting, if painful, reading. Glad to see it isn’t simply me. (simple me?). My question does remain, if I choose to first convert the files to ProRes, what flavor would be my best choice.
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
  • Mark Spano
    September 29, 2010 at 11:09 pm
    I’ve had good results with original recipe Apple ProRes as well as ProRes LT. HDV is a 25 Mbps codec, so the 100 or 145 Mbps flavors here should keep as much of the quality of the original and give you I-frame goodness and 10-bit headroom nicely.
  • Phil Balsdon
    September 29, 2010 at 11:15 pm
    You can capture HDV via firewire as ProRes.
    https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
    It may be camera dependent but this should also bring the camera timecode with it.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://www.steadi-onfilms.com.au/
  • Martin Nelson
    September 29, 2010 at 11:28 pm
    [Phil Balsdon] “You can capture HDV via firewire as ProRes.”
    Yeah, I would have preferred that, Phil. But it came to me pre-captured.
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
  • Phil Balsdon
    September 29, 2010 at 11:56 pm
    Not point in going above ProRes SQ. Infact going to ProRes HQ as well as being large files may actually cause more problems.
    If the project is not for broadcast and for DVD or the web ProRes LQ will most likely be sufficient.
  • Shane Ross
    September 30, 2010 at 12:20 am
    If the footage came to you pre-captured, then edit in a ProRes sequence. Yeah, you’ll have to render in the end, but trust me, you’re better off.
    Shane
  • Phil Balsdon
    September 30, 2010 at 12:37 am
    What Shane recommends for sure.
  • Martin Nelson
    September 30, 2010 at 1:40 am
    Gotcha, Shane. But it’s not a ton of footage. Am I better off converting the material to a ProRes compression first. If so, which?
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
