Is having too many clips on timeline cause of crashing? Possible work around?
I do believe (this is really a question) having too many clips on timeline might be cause of ms 13 freezing while editing?
I have 3 hours of clips on my timeline.
I know with Serif Movie Plus the more clips on your timeline the more likely it was to crash.
Yup, I am back to the screen freezing again.
Now, I know some people have offered other fixes, which I can try but I thought of a possible easy fix and just wanted to know if anyone sees a problem with this.
I could break the 3 hours on the SONY MS 13 into smaller projects of say 30 minutes.
Perhaps that will eliminate the screen freezing?
So then just edit the project in 30 minute segments.
I guess to get them all into the final project – I would simply render each 30 minute FINISHED segment to a file and then when all of the segments are completely edited, simply import them back into one project?
Will this work?
If I keep the render and import settings at the h def of 1440 by 1080 will I lose any picture quality given all of the rendering and importing?
Thanks for any help!
