Activity › Forums › Adobe Premiere Pro › is frame change possible after a project has started?
  • is frame change possible after a project has started?
    Posted by Ben Doherty on February 28, 2009 at 12:11 pm
    OK, i’ve been a mega noob and i’ve done all my editing, assuming that the reason that the sides were cropped off my footage was becasue the preview was zoomed in too far.
    I now see that it was becasue my frame was too small for my footage. fool!
    so no my challenge is to find a way of changing the size of my frame. i’ve tried numerous things, but to no avail, even exporting as an AAF, importign the project file back into a fresh file, etc.
    does anyone have a fix?
    thanks
    Ann Bens replied 17 years, 7 months ago 3 Members · 3 Replies
  • Mike Velte
    March 1, 2009 at 11:44 am
    [Ben Doherty] “I now see that it was becasue my frame was too small for my footage. fool!”
    What is the resolution of your stills? What is your target audience…web, dvd, local playback?
  • Ben Doherty
    March 1, 2009 at 1:53 pm
    The footage was from a screen capture, on a reduced area of the screen, so it was something like 1100×600. It was for local playback, so that the screen text was visible.
    The best I could get out of it is now here, taking advantage of the fact that one can download the full resolution file once logged in. – https://vimeo.com/3408974
    It’s especially galling as the capture file is absolutly crystal clear, image and sound, and is only 25mb, but the best i could do (using the techsmith codec) was 150mb, and it looked like a toddler had been left alone with a pack of highlighter pens.
    but that’s off the topic of the initial question i suppose. Is it possible to change the frame size once a project has started?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Ann Bens
    March 1, 2009 at 3:27 pm
    In CS4 make a new sequence, copy from old sequence and drop it into the new.
    Other versions you will have to make a new project with the settings set in the editing mode/desktop. Import older project into new one.
