Activity › Forums › Apple Final Cut Pro Legacy › Is FCS2 shipping May 1st? — Better clone…
  • Is FCS2 shipping May 1st? — Better clone…
    Posted by David Roth weiss on April 21, 2007 at 5:35 pm
    Am I correct in assuming that Apple will be shipping on or around May 1st?
    In anticipation I’m cloning my current system drive right now to create a safe backup just in case FCS2, like most initial software releases, isn’t completely ready for prime time. I recommend that everyone here who works for a living do the same before updating or upgrading your FCP systems.
    DRW
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
    Michael Sacci replied 19 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • John Foley
    April 21, 2007 at 5:44 pm
    Could be May 01 or could be May 31. Apple says it will ship in May.
    And Yes, it is better to begin with a fresh install of everything. Spring Cleaning for your MAC.
    I plan to make a complete backup on a Firewire drive, so I can get to FCP 5.1 should I want to.
  • Stuart Ferreyra
    April 21, 2007 at 7:40 pm
    I would recommend not to buy until 6.0.1
    As of NAB, the new versions of FCP and Motion were still betas….
    Stuart Ferreyra
    Timecode Multimedia
    President
    Santa Monica, CA 90025
    https://www.timecodemultimedia.com
  • David Roth weiss
    April 22, 2007 at 12:16 am
    [Timecode Multimedia] “I would recommend not to buy until 6.0.1”
    I don’t disagree with you at all. I’m not usually a bleeding edge updater, but, I’m getting mine early this time around so I can start learning the new things as soon as possible. I’ll have my 5.1.4 clone on standby for on-going projects and anthing mission critical.
    David Roth Weiss
    Los Angeles
  • Winston A. cely
    April 22, 2007 at 3:13 am
    OK, we can all agree that having your system as it stands right now backed up so you don’t have to worry about “down time.” What I would like is a link to a step by step process of creating a firewire back up over my main system that I could work from, “just in case.” Does that even make sense?
  • David Roth weiss
    April 22, 2007 at 3:50 am
    [Winston A. Cely] “Does that even make sense?”
    Not entirely, but perhaps you’re not certain how a system clone works. First, get yourslef a copy of Carbon Copy Cloner. Its free, which is a pretty good price if you ask me. Now, clone your system drive to any firewire drive. Now, go into System Prefs and change the boot disk to boot to your clone for a test. Voila, you can boot to that drive. Now, change back to your original system disk in the computer and store the clone on your shelf. When you load FCS2 you’ll know that at anytime you just go back to your old version by booting off the clone.
    David Roth Weiss
    Los Angeles
  • Neil Sadwelkar
    April 22, 2007 at 5:13 am
    All our systems have two drives internal. When such an upgrade situation looms, we install another OS on the spare drive and load the new app there. Anything boken we just boot back with the original drive. Any kind of cloning and restore from clone process is time consuming.
    And hey, even if its broken, there are enough exciting new things in FCS 2 that will definitely work fine.
    Neil
    FCP Editor, Mumbai, India.
    Completely PAL.
  • Michael Sacci
    April 26, 2007 at 8:18 am
    I will update on day one, I go the install on a separate drive. If you do this make sure you back up your project files before opening them in the FCP6. I love being on the bleeding edge but always keep the bandaids close. With the two drive setup you are minutes away from going back.
    I have a G4 867 that has three OSs on it, 9.2, 10.3.? and 10.4.9. I still need to true OS9 boot for my Sonic encoder card.
