Activity › Forums › Apple Final Cut Pro Legacy › Is FCP 7 backwards compatible?
Christian Castillo replied 14 years, 2 months ago 14 Members · 23 Replies
Sherril Schlesinger
February 17, 2010 at 3:34 amHi,
I read the thread here that FCP 7 is backwards compatible with FCP 6 using XML to export the project from FCP 7….but when I try to open the project in FCP 6.0.6 – it opens a different project that I’ve been working on for months….and when I try to import an XML file – I get the error message: no translation templates matching the selected XML file were found. Unable to import this file.
Can anyone weigh in on these compatibility issues? I have a huge project on FCP 6 that I simply cannot compromise in ANY way with this new FCP 7 project!!!
Any help would be appreciated.
Shinx -
Jeremy Garchow
July 12, 2010 at 8:51 pm[Sherril Schlesinger] “Can anyone weigh in on these compatibility issues? “
File > Import > XML will get there for you. Sounds like you are trying to import the XML file as a regular file.
Jeremy
Sherril Schlesinger
July 12, 2010 at 8:58 pmHi Jeremy,
Thanks – my post was from February….I figured it out and the project is almost complete 🙂
Best
Sherril -
Geoff Hug
October 11, 2010 at 3:16 pmwould an fcp 7 file be backwards compatible with fcp 5 via xml file? if so, any idea which one? thanks,
Walter Biscardi
October 11, 2010 at 3:18 pm[Geoff Hug] ”
would an fcp 7 file be backwards compatible with fcp 5 via xml file? if so, any idea which one? thanks,”Probably XML version 1 or 2.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
Sherril Schlesinger
October 24, 2010 at 5:20 pmSo sorry for the very late response…..you probably have it figured out by now! I haven’t ever tried taking a project from FCP 7 to 5, but I’d imagine an earlier version of XML may work….try 1 and 2 and see which one opens in FCP 7.
Sherril
Jeremy Harmsen
December 30, 2010 at 6:21 pmHm.. the forum stops at a terrible place. I am in the same boat, and trying to edit a huge FCP project on an overheating macbook is very stressful. I have access to a mac pro today but it only uses FPC version 5. When I try the XML workflow to import a FCP 7 into FCP 5 it asks me for a “translation document file.” Help?
Jeremy Garchow
December 30, 2010 at 6:55 pmFile > Import > XML. You can’t just drag it in to the browser or import like a regular video file. You must use the XML import menu.
Shane Ross
December 30, 2010 at 7:06 pm[Jeremy Harmsen] “When I try the XML workflow to import a FCP 7 into FCP 5 it asks me for a “translation document file.” Help?”
You need to go FILE>IMPORT>XML. Then locate the XML. Not just FILE>IMPORT.
Shane
Read my blog, Little Frog in High Def -
Sherril Schlesinger
December 30, 2010 at 11:13 pm…and make sure you are using the right version of XML…it would be an earlier version for FCP 5.
