Activity › Forums › Blackmagic Design › Is Extreme compatable with QSDI?
  • Luke Maslen
    May 2, 2005 at 7:55 am
    Hi John,
    QSDI is a compressed video format which is transferred through SDI connections. DeckLink cards use uncompressed SDI and will not accept compressed QSDI data.
    In any case, if the DSR-1500 already has the optional board with SDTI (QSDI) ports, it should also have normal SDI ports which you can happily use with DeckLink cards.
    Regards,
    Luke Maslen
    Blackmagic Design
