Activity Forums Adobe After Effects Is Dynamic Link My Friend?
  • Is Dynamic Link My Friend?
    Posted by Gabi Bucataru on May 21, 2012 at 5:18 pm
    Hi Gang –
    I am battling with importing/exporting clips back and forth from Adobe Premiere to After Effects and back.
    Tried to do this via dynamic link but it slows the whole system down. Are there any hidden settings I should be aware of? or should I just render out my AE comps and then import them into Premiere as individual clips?
    In that case what render formats should I use?
    thanks a ton!
    Gabi
    Gabi Bucataru replied 14 years, 3 months ago 2 Members · 4 Replies
  • Roland R. kahlenberg
    May 21, 2012 at 9:32 pm
    DL can be a hassle/issue at times. Which version of AE are you using? DL is supposed to be improved in CS6.
    A workaround is to copy the clips from PPro and paste them into an AE Timeline.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Gabi Bucataru
    May 22, 2012 at 4:29 pm
    Thanks Rork –
    I am using PR and AE CS5. Some people recommended copying AE compositions into Pr directly. Would that run a hidden instance of After Effects, thus eating up memory and CPU?
    I am mostly concerned of performance.
    thanks for the help!
    Gabi
    May 23, 2012 at 10:45 pm
    In CS5, PPro, AE, Encore and Media Encoder all share the same memory space. So, having both apps open will not increase memory requirements over what is set in the Memory & Multi Processing preferences.
    HTH
    RoRK
  • Gabi Bucataru
    May 29, 2012 at 3:00 pm
    Thanks Rork!
    that makes sense. I found that things are REALLY bogged down with even copying comps into PrP 5 since at that point a dynamic link is created and I am back in the same boat again. Thing is that I don’t have an uber complicated AE comp so I don’t understand the super slowing down of PrP’s time line.
    thanks!
    Gabi
