Activity Forums Apple Final Cut Pro Legacy Is doing heavy editing and rendering with a WD My Book II a bad idea?
  • Rafael Amador
    May 18, 2013 at 5:50 am
    Personally I will keep away from WD for the rest of my life.
    I’ve bought 4 WD hard drives and three out of the four died after just few weeks of use and without any hard work.
    Rafael
  • David Eaks
    May 18, 2013 at 4:43 pm
    There are horror stories for every brand HDD, the thing is, they all suck and will fail. So have a backup system in place. I have personally had very good experience with Western Digital (primarily buying bare drive Caviar Blacks).
    It looks like the drive you linked to uses the WD Green drives, which are “intellipower” and run somewhere between 5400 and 7200 rpm. Not usually recommended for video work, but I’m sure at the end of the day it will do the job.
