Activity › Forums › Adobe After Effects › Is DOF simulation possible?
  • Is DOF simulation possible?
    Posted by Joe Wentrup on February 17, 2008 at 11:50 pm
    Is there any possibilitie to create virtual shallow DOF with filters? I don´t refer to 3D applications but to real world footage: For example, take 2/3″ camera footage and increase the blur of already blurred areas in post until you get a 35mm look. Would that bie possible, at least in certain circumstances?
    joe 1008
    Pierre Jasmin replied 18 years, 7 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    February 18, 2008 at 6:26 pm
    I have not seen anyone do a good job at it with a pure computer vision / image processing basis except with specially callibrated multiple simultaneuous views (eg the Microsoft Research demo uses 5 cameras), or maybe in very particular cases (like a pure pan without object motion as a source).
    However often you can do a good job by cutting the image into regions with 3-4 roto masks, setting the alpha to eg 0.25, 0.5, 0.75 and 1.0 and then fiddling with that in SmoothKit ZBlur as your starting Z map base.
    Pierre
