Activity Forums Maxon Cinema 4D Is core enough to …
  • Is core enough to …
    Posted by Rob Ainscough on February 6, 2010 at 8:54 pm
    I’m trying to decide on whether or not I want to get Cinema 4D or TurboCAD Pro v5.
    What I need to accomplish:
    1. Create 3D objects to very specific dimensions (Auto’s upper and lower control arms with shock/spring)
    2. Animate suspensions motion with control arms and shocks and springs.
    TurboCAD Pro v5 ($500) seems to be limited in animation abilities (it can’t actually animate it’s objects). So it seems Cinema 4D is high on my list ($1000). So the question is, does Cinema 4D Core have enough of what I need to accomplish my tasks? Or do I need some of the extensions for Cinema 4D Core ($2500 – $3500)?
    Rob.
    Rob Ainscough replied 16 years, 7 months ago 2 Members · 4 Replies
  • Randy Johnson
    February 7, 2010 at 9:53 am
    Yes, For that type of animation you can get it done with core. You will need to learn a bit of expresso (node based controls). You would be better off with some constraint options, you can get this with MOCCA module or a cheaper and powerful option is this plug in set
    https://www.cactus3d.com/Plugins.html
    /Randy
  • Rob Ainscough
    February 7, 2010 at 7:35 pm
    Randy,
    Thanks for the response. The Cactus3d plug-INS look interesting, but I’m not clear on which ones will meet my needs?
    Character Bundle Pro ? $250
    Thanks Rob
  • Randy Johnson
    February 8, 2010 at 3:35 pm
    You are looking for IK tools and constraints.
    /Randy
  • Rob Ainscough
    February 8, 2010 at 3:51 pm
    Thanks Randy.
