Activity Forums Adobe Premiere Pro Is Canon XL2 fully compatible with Pre Pro 1.5
  • Is Canon XL2 fully compatible with Pre Pro 1.5
    Posted by Don Solomon on August 16, 2005 at 8:53 pm
    Is anyone using the Canon XL2 with Prem Pro? Are there any problems capturing or recording back to tape with any of the XL2 formats? I am planning to buy an XL2 but notice that it is not supported in the device list–which doesn’t mean it won’t work. I have to be sure of that before I make a purchase. I need full deck control for output to it. I would hate to have to change editing software! Any info you could provide would be much appreciated. TIA
    Don Solomon replied 21 years ago 4 Members · 5 Replies
  • Scott
    August 17, 2005 at 2:25 am
    Premiere Pro will NOT capture audio from the ST2 audio tracks. You need a stand alone utility if you want to do that. Otherwise, I have no problems with it.
    Scott
  • Don Solomon
    August 17, 2005 at 1:37 pm
    Thanks Scott, but I am not sure what you mean by the ST2 tracks? Also, am I right in presuming you have no trouble controlling the deck when you print to tape?
    don
  • Tim Mirande
    August 17, 2005 at 5:17 pm
    BTW, same issue with the GL2. I use Scenalyzer for capture & it works flawlessly. Any idea why this is – and why Adobe can’t seem to fix it?
    Tim
  • Chad Treanor
    September 6, 2005 at 8:25 pm
    I shot a short film on an XL2 and tried to digitize the dailies at the end of the day. When I connected the XL2 via firewire – premiere recognized it and the footage showed up on the digitize window. Once I started to dig. the footage it would dig. for about 90 seconds and then come up with a smaller error window that only said – Record error – with an option to hit ok… After doing this 6 times I decided something was not compatible with P.Pro.
    I tried all the dif. capture settings within P.Pro and still the same error came up. I was really dissappointed because I was looking into getting an XL2 because of the amazing video quality and multiple shooting options. Since I’m a P.Pro user I went another direction.
    I have a dell XPS system with XP pro.
    3.2 GHz processor with a Gig of RAM.
    160 gig external media drive.
    Hope this helps.
    Chad Treanor
  • Don Solomon
    September 11, 2005 at 8:26 pm
    Thanks Chad, sorry to not have responded sooner. Out of town.
    When you say you ‘went another direction’ what do you mean. I presume you mean that you had to go to another NLE. If so, which one? I too wanted to use PPro with mine (which I have not received yet.
    I am very disappointed to hear that PPRO will not work with the XL2. Have you contacted Adobe? I am finding it very hard to get feedback on the status of the XL2 with Adobe.
