Activity › Forums › Blackmagic Cameras › is bmcc 23.98 really 23.976
Posted by Ali Quintana on December 2, 2013 at 10:44 pmI just did a whole 30 sec editing on BMCC footage sot at 23.98.
Now I hear on an other forum that its should really be 23.976, can any one confirm if this is right? and if so, should I re set my comp to 23.976 and need to re-edit?
John Fishback replied 12 years, 10 months ago 3 Members · 5 Replies -
Michael Phillips
December 3, 2013 at 3:06 am23.98 is the shorthand for 23.976 and shouldn’t really be a difference in the NLE.
Michael
John Fishback
December 4, 2013 at 9:41 pmMichael is correct about most NLEs using 23.98 as shorthand for 23.976. However, in an app like After Effects, I believe you can set 23.98 as a frame rate and that would cause problems.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Ali Quintana
December 5, 2013 at 10:47 pmOK, but still The
Black Magic cinema Camera has a frame rate selection and says 23.98
My original question is if this is really 23.976? or is it like it
says 23.98? -
Michael Phillips
December 5, 2013 at 11:04 pmI will bet a large sum of something that from a camera’s perspective, it is really 23.976 and is shorthand for space considerations in menu selection or something like that.
michael
John Fishback
December 5, 2013 at 11:06 pmIt records 23.976.
John
