Activity › Forums › Apple Final Cut Pro Legacy › Is batch exporting/renaming segmented files from timeline possible?
  • Is batch exporting/renaming segmented files from timeline possible?
    Posted by Bob Accettullo on May 18, 2011 at 3:54 am
    I have a 3 hour timeline of a company meeting. The client wants the timeline split into 50 new files that they can post on their server as WMV files.
    My question, can someone tell me if I can mark simple in/out points on the FCP timeline and “batch” export a new quicktime of each of the many new files.
    I don’t want to have to go file/export/quicktime/standalone for every segment. I didn’t know if there is an easier way saving some hours?
    My goal is to make 50 .WMV files one very long timeline. Once I make the new .mov I have a file converter that can batch automate. But how to batch export these edits from FCP is the question?
    Thanks in advance!!
    Bob in Boston
    Adam Taylor replied 15 years, 4 months ago 4 Members · 5 Replies
  • Neil Sadwelkar
    May 18, 2011 at 4:23 am
    One method would be to make 50 dupes of your timeline. And in each dupe keep only the portion you need deleting the rest. Then batch export these 50 timelines. File > Batch Export.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Adam Taylor
    May 18, 2011 at 7:44 am
    or perhaps you could make subclips for each section, then highlight all the subclips in the bin and batch export those?
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Jeremy Garchow
    May 18, 2011 at 11:31 am
    I don’t know where you are doing your compressing, but perhaps the program you are using to compress with has in and out capability. I know Compressor and Episide do. You can even add Fade up/fade outs.
    Jeremy
  • Bob Accettullo
    May 18, 2011 at 4:09 pm
    Thank you all for these great ideas. Almost there I think….
    Adam, the method you described is what I was thinking, but is there a method of “batch” exporting the subclips for overnight render? If so how? (my segmented timeline is 3 hours, ouch!) So the creation of the sub clips to new files is sort of the painful step.
    Once I have the 50 new subclips in a bin I can either use Compressor
    or other conversion software.
    The client wants the 50 clips as .wmv files. I think last year I made them .mpg files using apple Compressor and windows media player played those fine.
    Thanks for any additional info.
    Bob Accettullo
    Boston, Ma
  • Adam Taylor
    May 20, 2011 at 7:57 am
    you will need to create your subclips first, then within the folder containing the subclips you hold shift whilst selecting all you want to export. Then select Send To …Compressor.
    This will ask if you want to send as individual clips or combine them into one – choose individual.
    When Compressor opens you can select all the clips and drag a setting onto one, which will place the same setting on each clip.
    You will need to create your own wmv setting as Compressor doesnt have one as standard. Search the cow for instruction on this (its how i learnt it). Then submit the job and your batch will happen. You may want to look into using QMaster to speed things up – the instructions are within its help files, and should be already installed with your FCP.
    adam
    Adam Taylor
    Oldham, UK
