Activity › Forums › Avid Media Composer › Is an FCP style Edit with Transition possible in AVID?
  • Is an FCP style Edit with Transition possible in AVID?
    Posted by Jerry Sneede on January 20, 2015 at 7:51 pm
    In FCP I’m used to assigning a dissolve length, say 12 frames, to a favorite, setting that as the default, then using Edit with Transition. It’s not a big deal, but it does save some time.
    Is there anything like this in AVID?
    Christopher Travis replied 11 years, 8 months ago 5 Members · 5 Replies
  • James Patterson
    January 22, 2015 at 3:02 pm
    If you make a bin called ‘quick transitions’ and put custom transitions inside they will be added to your list when you select ‘quick transition’ it’s not one button but it’s a good way to have a batch of options at hand. if you do drop a 12 frame dissolve down on a clip the next time you open quick transition it should remember what you just used.
    Best
    Paddy
  • Bill Stephan
    January 22, 2015 at 6:10 pm
    Set up a 12 frame dissolve on an edit in the timeline. Then, in the effect editor window, drag the purple effect icon at the top into a bin. Rename the effect in the bin so you know what it is. To use the effect, just drag it from the bin and drop on an edit in the timeline. This is a great method to deal with complicated effects that mmust be used multiple times.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • William Busby
    January 23, 2015 at 4:08 am
    btw… I believe the bin is case sensitive, Quick Transitions, if all lower case I don’t think it will work as intended
  • Jerry Sneede
    January 23, 2015 at 5:42 pm
    That’s great to know, thanks!
    Another question – In FCP there’s a keyboard shortcut for lower or raise audio on a track 1 or 10 db. Is there any such thing in AVID? Looks like you have to go into the mixer each time.
    – D
  • Christopher Travis
    January 28, 2015 at 6:47 pm
    There isn’t a shortcut for adjusting my multiple Db at a time but if you’re in MC7 or later (I think), you can adjust the gain on clips on active tracks by 1Db at a time, with opt+down arrow. That’s from memory though, it might not be right. If not, hopefully someone can correct me.
