Activity Forums Apple Final Cut Pro Legacy Is an AVI Export possible?
  • Is an AVI Export possible?
    Posted by Robinson on December 23, 2006 at 4:25 am
    I need to find out if i can export a sequence as an AVI file from FCP. If it is possible then, is there a possibility of a lossless/ uncompressed transfer (HUFF YU?)
    Thanks in advance!!!!
    Rafael Amador replied 19 years, 9 months ago 5 Members · 5 Replies
  • Rich Rubasch
    December 23, 2006 at 5:42 pm
    Export a ref QT and get MpegStreamclip (squared5.com). It will then export the AVI movie. Remember that you have a 2 gig file size limit so you have only a little over 2 minutes before you run out of space. However if you use PJPEG compression on the AVI (Streamclip now supports it) you can put longer clips into the AVI container.
    Have a look.
    Rich Rubasch
    Tilt Media
  • David Miller
    December 23, 2006 at 5:46 pm
    the only way that I can think of trying other than exporting a ref and putting it through cleaner is to look at https://www.flip4mac.com/. They have an encoder that may work within the export of FCP but I haven’t tried it.
    good luck
    david
  • Ernie Santella
    December 24, 2006 at 4:51 am
    You can export out of FCP as an AVI file. Just export using the Export-Quicktime Conversion menu. Then under Format, change to AVI. Then under AVI settings, set the video settings to None (Uncompressed) Also, make sure you change the depth to Millions.
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Rafael Amador
    December 24, 2006 at 4:52 am
    You can do it directly from FC using QT convertion (mov to AVI), but as Rich says with MPGstreamclip you got more options than with QT.
    Salud,
    Rafael
  • Rafael Amador
    December 24, 2006 at 2:16 pm
    But don’t mistake NONE (RGB 444) with 8/10bits Uncompressed (YCrCb 422). The first one make huge files.
    Salud,
    Rafael
