Activity Forums Apple Final Cut Pro Legacy Is all RAM created equal
  • Is all RAM created equal
    Posted by Don Forschmitt on June 8, 2005 at 11:05 pm
    Presently have 1 GB of RAM and want to install another GB. I see it is sold as two 512 chips and the prices range considerably from Apple to other sellers. Is there anything I should be watching out for as far as vendors.
    Thanks for any guidance!
    FCP 4.5 HD
    Dual 2gig G5
    1 gig RAM
    2 internal drives 160GB/250GB
    G-RAID 500 GB
    G-Drive 160 GB
    UVW-1800
    DSR-11
    AJA IO la
    http://www.primelight.net
    Sean Oneil replied 21 years, 2 months ago 6 Members · 6 Replies
  • Suzanne
    June 9, 2005 at 12:14 am
    Most RAM you get is pretty reliable. The only RAM that I’ve personally had trouble with in the past is Kingston Value RAM. Kingston makes different RAM, but the “Value” kind has frozen up on me. Could have just been a bad batch, but I won’t buy it anymore myself.
    Good luck!
    Suz
  • Jimr
    June 9, 2005 at 12:20 am
    I personally like Crucial ram.
    Buy all my Ram from them and Never had a problem.
  • Walter Biscardi
    June 9, 2005 at 12:21 am
    http://www.crucial.com is the only place I recommend. I also recommend keeping all the RAM as a matched set, i.e. all from the same manufacturer.
    When I purchase a new machine, I order it with the bare minimum RAM, then replace it all with Crucial RAM. 4GB in one G5, 3GB in another G5 and 1GB in my Powerbook, all working fine.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Don Forschmitt
    June 9, 2005 at 12:43 am
    Thank you all for such quick responses. I am always amazed.
    FCP 4.5 HD
    Dual 2gig G5
    1 gig RAM
    G-RAID 500 GB
    G-Drive 160 GB
    UVW-1800
    DSR-11
    AJA IO la
  • Fred Miller
    June 9, 2005 at 3:45 am
    Make sure you do a hardware test after installing the RAM.
    G5 2Gg Dual
    1.5Gg RAM
    Panther
    ATTO UL3D
  • Sean Oneil
    June 9, 2005 at 6:32 pm
    There are a lot of very confusing specs for RAM like CAS latency and other types of timing and things like that. Unless you know what those are and what a G5 is optimized for, make sure the RAM is advertised as Mac compatible.
