Activity › Forums › AJA Video Systems › is AJA sitting on their Laurels??
Pat Mcgowan replied 17 years, 4 months ago 11 Members · 41 Replies
Vince Becquiot
April 12, 2009 at 1:28 amWe are actually using the AJA Xena to playback to SDI to a Panasonic HD monitor. I was told by AJA themselves that they currently do not support the 30 PN format, a very popular format for non broadcast applications.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Gary Adcock
April 12, 2009 at 1:22 pm[Vince Becquiot] ” was told by AJA themselves that they currently do not support the 30 PN format, a very popular format for non broadcast applications. “
Thats because it is not video. AJA makes VIDEO CARDS not graphics cards.
SMPTE rules say that the 720 format needs to have 59.94/ 60 frames- 30pn does not conform any more than 720p24 does.
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Jeremy Garchow
April 12, 2009 at 4:15 pm[Vince Becquiot] “We are actually using the AJA Xena to playback to SDI to a Panasonic HD monitor. “
Hmm, well I have no experience with a Xena, but 30pN is fully supported with the Kona/Mac platform. Like Gary alluded to, when played back, the Kona/FCP add 2:2 pulldown to conform to SMPTE 720p59.94.
Jeremy
Vince Becquiot
April 12, 2009 at 5:02 pmGary, my post was in the spirit of requests posted above, and less of “expectation”.
That being said, as you know 30pN will cut your precious recording space nearly in half on a SS card, and while I know it is no SMPTE standard, it is still a video format used by many solid state shooters. We just have no way to play back a native timeline through SDI either to tape or for preview.
Vince Becquiot
Kaptis Studios
Vince Becquiot
April 12, 2009 at 5:05 pmIt does show the correct pulldown on the monitor itself, but the image cuts off and appears scrambled 3/4 of the way on the right side and bottom.
Vince Becquiot
Kaptis Studios
Gary Adcock
April 12, 2009 at 6:32 pm[Vince Becquiot] “It does show the correct pulldown on the monitor itself, but the image cuts off and appears scrambled 3/4 of the way on the right side and bottom. “
then the firmware is not correct on your board.
As jeremy said – the card will add the correct pulldown.
gary adcock
Studio37
Vince Becquiot
April 12, 2009 at 6:54 pmGary,
I do have the latest firmware. And while it does add the correct pulldown, I think the card has issues with the format itself. The exact same thing happens on the BM cards, and AJA’s answer was that 30pN is not supported at this time.
I certainly would love to find work around for this issue, but I spent hours trying. We are currently using DVI on a second Quadro FX card to output to an Panasonic LH 1760, but we have a slight audio delay due to processing (I guess this could be solved by a delay unit), as well as issues with frame aspect ratio.
Due to the fact the the monitor is actually 16:10, the footage get stretched vertically, and not way to keep the Quadro FX in non scale 1280×768, it just goes back to its default scaling setting.
Vince Becquiot
Kaptis Studios
Jeremy Garchow
April 12, 2009 at 8:38 pm[Vince Becquiot] “I do have the latest firmware. And while it does add the correct pulldown, I think the card has issues with the format itself. The exact same thing happens on the BM cards, and AJA’s answer was that 30pN is not supported at this time. “
Is this from Premiere? What OS/system are you on?
Jeremy
Vince Becquiot
April 13, 2009 at 4:23 am
