Activity Forums Zaxwerks IS ADOBE ILLUSTRATOR The only game in town.
  • IS ADOBE ILLUSTRATOR The only game in town.
    Posted by Paul Whishaw on April 6, 2005 at 6:58 am
    Is Adobe Illustrator the only way to get text objects into Zax? I have Freehand but I’m still stuck running AI in Classic mode with a spattering of pathetic fonts. Have they at least upgraded to alow versions higher than AI 9? Just curious. Thanks in advance.
    Matt Rhodes replied 21 years, 5 months ago 3 Members · 2 Replies
  • Compty
    April 6, 2005 at 11:16 am
    Hi Paul,
    It is not compulsory to use Adobe Illustrator.
    I use CorelDraw12, convert my texts to curves, then export to AI (version 7) and so far have not hit a single problem. Once in Invig or in ProAnim I would set the Spikebuster to 100 and choose the appropriate edges. All can be found under the Objects tab.
    As for the version higher than AI (V9), I also use Adobe Illustrator CS and found no related issues with the either of these applications.
    Hope this helps
    Regards
    MaxC
  • Matt Rhodes
    April 6, 2005 at 3:27 pm
    Hi Paul.
    Version 4.x of Zaxwerks Invigorator 3D and any version of ProAnimator has a Text editor built in,
    so in many cases, you won’t need to import any outlines. You can do all of your editing within Invigorator.
    Take a look at the demo version to see if it fits your needs.
    Let me know if I can offer further assistance.
    Matt Rhodes
    Zaxwerks, Inc.
