Activity Forums Apple Final Cut Pro Legacy Is a partition and a dual boot the same thing?
  • Kent Stipp
    May 8, 2009 at 4:55 pm
    if it is possible get a second drive and set it you as a boot drive for your Avid. That is what I do with one of my machines one drive has FCS 2 and the other is Pro Tools.
    Partioning a drive is a solution but not a best case. when you do that you actually loose drive performance.
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
  • Carlos Castro
    May 8, 2009 at 4:59 pm
    OK Kent,
    I’m open to that suggestion. How is that done? Do you happen to have a link I can follow?
    How do you get the OS on the new drive?
  • Kent Stipp
    May 8, 2009 at 5:03 pm
    after you install the 2nd drive in your computer. make sure you format it in disk utility. after that either use the install/restore disk that came with your computer to put the OS on the new drive OR purchase a new copy of the os and install on the new drive. to differentiate you might want to make sure you give the drive a different name like Media Composer.
    Kent Stipp
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
  • Carlos Castro
    May 8, 2009 at 6:00 pm
    I’ll try that Kent. I have a 2nd drive already in the system that I was using to store small projects {media} until I purchased a Raid drive, Do I need to strip it down { reformat] or just load the OS on to it. I fortunately have a 2nd copy of Leopard since I purchased a Mac Box set recently.
    Also in the future will I need to select a drive or program when I power up the system?
    thanks again for your help.
  • Richard Sanchez
    May 8, 2009 at 7:01 pm
    Kent,
    How does partitioning your hard drive cause you to lose performance? I only ask because I have this setup, with a 750GB drive partitioned into one OS for FCP and another for Media Composer. I haven’t noticed any performance issues, but I haven’t pushed it that hard since setting up the dual boot.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Kent Stipp
    May 8, 2009 at 7:31 pm
    mark,
    1st if you are going to use the 2nd drive you already have you will need to reformat and that will mean loosing data on that drive. On that note if that is your only “media” drive you need to figure out where you are going to put media. DO you have a 3rd internal or an external you can use for your media?
    to address the question on partitoning. As the tech’s explained. your drive generally writes from the inside out. So the main partition is on the inside and each subsequent partition works its was out giving you a lower performance. and with todays computers and drives being so inexpensive it is really just more efficent.
    Hope this helps
    Kent Stipp
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
