Activity Forums Adobe After Effects Is a 3 hour Render Time normal ?
  • Is a 3 hour Render Time normal ?
    Posted by Shahruk Hossain on September 13, 2016 at 3:46 pm
    I am doing a 3D sequence using an element 3D layer which has 15 objects imported into it and 4 layers with Particular on each to simulate fog/cloudy weather.
    Motion blur turned on in the element 3d layer
    Glow turned on in element 3d
    One camera
    50 second sequence
    The render is taking 3 hours. Is this normal or is it getting stuck somewhere ?
    My Specs :
    Running After Effects CS6 on
    i7 6700K, Z170A motherboard, DDR4 8GB ram, 960 GTX Strix Edition
    PS : This is my first post on this forum, so forgive me if I have left out any necessary info
    – Best Wishes, Shahruk
    Daniel Waldron replied 10 years ago 3 Members · 3 Replies
  • Shahruk Hossain
    September 13, 2016 at 8:12 pm
    Ahh thank you for the reply! Sorry I derped out and forgot to mention the comp settings, 1920 x 1080p , 30fps, 1500 frames
    I have turned off the physics factor on the particular layers though, so they are frozen; no new particles are being generated after the first second. I do have Gaussian blur on one of the particular layers to make the particle texture I am using seem more like a fog.
    A render on Best Settings took me 3 hrs and 21 minutes
  • Rohan Kolakkar
    September 14, 2016 at 6:21 am
    Hi Shahruk,
    if it is taking a long time to render out the output. you can render separate layer (separate particle, separate element, separate background) and then compile it together in to new file (if its taking a long time). hope thats works.
    Rohan Kolakkar
  • Daniel Waldron
    September 14, 2016 at 1:23 pm
    Sounds normal. Even a little fast, given your computer specs. 😉
