Activity › Forums › Adobe After Effects › Is 60% used of 1023MB alot when rendering out?
  • Is 60% used of 1023MB alot when rendering out?
    Posted by Daniel Haskett on May 29, 2005 at 8:35 pm
    Hi there
    Basically Ive started to render some stuff out at Loseless quality however the main problem Im having is that after a couple of minutes it reaches around 58% of 1023mb used and takes alot longer than was previously estimated. If it initally says 30mins to render it will take about 3 hours in the end…is this usual and if not, is there anything I can do?
    Thanks in advance!
    Dan
    Patrick Pathmanathan replied 21 years, 4 months ago 5 Members · 4 Replies
  • Zack Bryne
    May 29, 2005 at 8:40 pm
    Mine always says using 60% also, someone else probably knows more detail on it
  • Steve Roberts
    May 29, 2005 at 9:34 pm
    Search the COW using “secret” or “schecret” as a search term. Try the archives as well.
    Steve
  • David Johnson
    May 30, 2005 at 12:25 am
    “initally says 30mins to render it will take about 3 hours in the end”
    60% is about right and the estimated render time is supposed to update based on the difficulty of the frame that’s rendering at the moment…so if your comp starts with a simple dissolve and progresses into more complex FX, the dissolve will render quickly, but rendering of the overall comp will slow down and/or speed up depending on the relative difficulty of the frames that follow.
  • Patrick Pathmanathan
    May 30, 2005 at 4:38 pm
    – try closing all other application running other than AE, that includes your task bar applications too.
    – Currently your default Ram setting is 60%, Go to edit…then preference, and increase the ram percentage to 80-90%.(Don’t use 100%, you need some to run the application.)
    -Patrick.P
