Activity › Forums › Apple Final Cut Pro Legacy › Is 17 mbs bitrate too low for BD?
Posted by Chris Babbitt on November 22, 2010 at 9:13 pmI have a 3-hour program that I want to fit on a single 25gb Blu-Ray. In order to do it, I will need to encode at 16.8 avg. data rate (MP2). Will that give me decent quality, or am I wasting my time? Dual layer is too expensive and Compressor won’t do H.264 for BD.
Eric Pautsch replied 15 years, 10 months ago 6 Members · 23 Replies -
Walter Biscardi
November 22, 2010 at 9:28 pmThat’s pretty low for sure. Would go for the DL BluRay quite honestly.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
Rafael Amador
November 22, 2010 at 10:21 pmI agree with Walter.
For an H264 could be OK, but very low for MPEG-2.
On a HD MPEG-2, that would yield similar quality than a 3Mbps data-rate on an DVD.
rafael -
Eric Pautsch
November 23, 2010 at 1:02 amAn Avg of 17 mb/s is fine. You can also set a peak setting as well in case your footage needs it. However, it also depends on the encoder you use and how well your source file is. Ive authored titles with a 14 mb/s avg and they look great…then again, I’ve never used Compressor for BD work. Do a test and see.
Lot of titles done with bitrates lower than that. Here’s a site which list some averages:
https://forum.blu-ray.com/blu-ray-movies-north-america/3338-blu-ray-movie-bitrates-here.html
Joseph Bradley
November 23, 2010 at 1:53 amH-264 is usually used with MPeg4 not MPeg2. I’ve done several outputs using MPeg4 with H-264 and it looked great. Of course that depends on how good the footage was on import. I use FCP to output the footage so you don’t need to use compressor.
Rafael Amador
November 23, 2010 at 8:55 am[Joseph Bradley] “H-264 is usually used with MPeg4 not MPeg2. I’ve done several outputs using MPeg4 with H-264 and it looked great. Of course that depends on how good the footage was on import. I use FCP to output the footage so you don’t need to use compressor.”
The question is not about MP4/H264.
The question is about MPEG-2.
How will look a 1080 MPEG-2 at 17Mbps?
rafael -
Chris Babbitt
November 23, 2010 at 4:35 pmSo, if you’re not using Compressor, you must be using Quicktime to do the encoding, and neither Quicktime nor Compressor will make a blu-ray compatible H.264 file. So, what’s your secret, Joseph?
Steve Connor
November 23, 2010 at 5:33 pmWhy won’t compressor make a BluRay compatible file? I’ve made a few that have been used in Adobe Encore with no problems at all
Steve Connor
Adrenalin TelevisionHave you tried “Search Posts”? Enlightenment may be there.
Steve Connor
November 23, 2010 at 5:45 pmIt does do h264 for Blu-ray, certainly the latest version does at least. I know because I’ve done it numerous times
Steve Connor
Steve Connor
November 23, 2010 at 5:50 pm
