Activity Forums Adobe After Effects Iris Wipe Transition
  • Iris Wipe Transition
    Posted by Paul Factora on July 28, 2006 at 1:45 am
    New to After Effects here.
    Just wondering how to add an Iris Wipe transition from one clip to another.
    Paul
    Avid Media Composer 8000XL
    Version 7.24
    Mac 9600/350 OS 8.6
    Sonnet G4 800 968 Ram
    Steve Roberts replied 20 years, 1 month ago 2 Members · 1 Reply
  • Steve Roberts
    July 28, 2006 at 2:03 am
    Remember that After Effects deals in layers, and doesn’t quite work like an NLE. Applying a transition to a layer makes the layer disappear/appear and reveals/hides whatever layers are beneath it.
    That said, you can apply effect>transition>iris wipe to the layer, and animate its radius using keyframes.
    If the iris’ 32 points (max) isn’t smooth enough, you might want to apply a circular mask (check the help) to the layer and animate its size by scaling the mask (ctrl-T: check the help) and keyframing the mask shape parameter in the timeline.
    It’s not as simple or fast as an NLE, but it’s a lot more powerful.
