Activity › Forums › Adobe After Effects › Iris in effect
  • Iris in effect
    Posted by Eilat Ben-eliyahu on January 5, 2019 at 8:07 pm
    I’m trying to create an “Iris In” effect from a video on a logo.
    So that most of the screen turns black, but not all of it.
    I would then hold the Iris’d in image (logo) for a few seconds before the whole picture fades to black.
    I did a very simple sketch, using crop and keyframes in Premiere pro – https://f1.creativecow.net/12994/12994
    However, it doesn’t look as professional and awesome as I would like it to be.
    What would you suggest?
    I’m quite a beginner with AE, but this seems basic enough. I’m just not sure what tools to use.
    So if you’ll describe me the right path, I would hopefully be able to make it work 🙂
    Also, I’m not sure what transition I should use to switch between the video and the graphic.
    Eilat
    Eilat Ben-eliyahu replied 7 years, 8 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    January 6, 2019 at 7:44 am
    I think you can do this in Premiere as easily. I would make a freeze frame of the footage for the logo rather than trying to replace it. You can use the corner pin to straighten it out so it is perfectly horizontal and vertical.
    The two main things I see as missing in the black layer with the iris shape are:
    1) Easing. An ease in to the send keyframe would make this nicer.
    2) Motion blur. This can be done as radial blur or with the transform technique: https://premierepro.net/motion-blur/
    If replacing the logo is critical, you’d have to align them perfectly and fade between the two. To make it more seamless, I would keyframe the color of the original footage to change during the iris zoom-in to match the color of the final logo, then it would not be an abrupt change to fade over to the final logo.
    Senior Graphic Designer
  • Eilat Ben-eliyahu
    January 7, 2019 at 2:41 pm
    Alright, thank you!
    Eilat
