Activity › Forums › Adobe Premiere Pro › Iris-in effect (not as a transition)
  • Iris-in effect (not as a transition)
    Posted by Eilat Ben-eliyahu on January 5, 2019 at 1:36 pm
    Dear friends,
    I’m excited! I’ve been using pieces of advice from this forum for years, and now is my first time to actually post a question.
    I would like to create an “Iris In” effect on a logo.
    So that most of the screen goes black but not all of it. I would then hold the Iris’d in image (logo) for a few seconds before the video fades to black.
    I did a very simple sketch, using crop effect and keyframing it: https://f1.creativecow.net/12994/12994
    However, it doesn’t look as professional and awesome as I would like it to be.
    What would you suggest?
    Is it even possible to do in Premiere, or should I get my hands on After Effects?
    Also, I’m not sure what transition I should use to switch between the video and the graphic. Morph cut didn’t work well.
    Eilat
    Todd Vanslyck replied 7 years, 8 months ago 3 Members · 3 Replies
  • Eilat Ben-eliyahu
    January 5, 2019 at 8:03 pm
    Alright, thank you!
  • Ann Bens
    January 5, 2019 at 9:32 pm
    Use the crop effect.
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
  • Todd Vanslyck
    January 7, 2019 at 2:29 pm
    Definitely After Effects, it’s much easier to control. You could animate a mask however you like.
    Maybe just a quick dissolve between the video and logo? Maybe you could run a subtle light sweep over the graphic right after the dissolve for extra flair.
    Good luck!
    TVS
    Dell Precision 5810 Intel Xeon 3.0 GHz
    NVIDIA Quadro M4000
    Adobe Premiere Pro CC
    After Effects CC
    Cinema 4d r14
