Activity Forums DaVinci Resolve IR Removal In Post
  • IR Removal In Post
    Posted by Kyle Lavore on December 10, 2013 at 4:31 pm
    Hello,
    This is probably a lost cause that will require a re-shoot, but I’m wondering if there is a way to remove IR Pollution in resolve. We shot on the BMCC (in RAW) using a 1.2 ND filter which caused the blacks to become reddish. Is there a known process to balance the blacks out?
    Best
    Christian Betong replied 12 years, 9 months ago 2 Members · 1 Reply
  • Christian Betong
    December 10, 2013 at 9:41 pm
    I use couple of techniques
    Custom curves: pull down on bottom of the red channel.
    Hue vs sat: pull down on the magenta a bit (IR usually pushes magenta a lot)
    Hue vs hue. Pull magenta up a little bit pushing it towards blue (this breaks the picture fast so pull gently)
    Hope to hear about other techniques as well
