Activity Forums Sony Cameras IR question
  • IR question
    Posted by Dano Motley on April 29, 2009 at 1:35 am
    can anyone recommend a good hot mirror to use to stop the ex3 from exhibiting a cranberry brown color on certain blacks (usually cloth) colors.
    i had the same IR problem years ago when i bought a sony dsr-200 and can remember the remedy.
    thanks in advance,
    Dano
    Dano Motley replied 17 years, 4 months ago 4 Members · 5 Replies
  • Kerry Brown
    April 29, 2009 at 1:46 am
    B+W 77E Infrared Cut Filter (486) 65-031976
    KB
  • Dano Motley
    April 29, 2009 at 3:14 pm
    thanks….
  • Derek Reich
    April 30, 2009 at 1:33 pm
    I agree wholeheartedly with Kerry. If you are using a mattebox, that filter is called the Schneider Tru-cut 680. Since it’s a ‘hot mirror’, it must be the first filter light hits. You will have some green vignetting at wide angle (15mm and wider) but it’s not too noticeable unless you’re shooting in a room with light walls. It works beautifully to correct for the IR contamination.
    cheers
  • Ralph Keyser
    May 1, 2009 at 8:21 pm
    I use the that 77E 486 filter as well and it seems to work fine. To add further complexity to this topic, you might check out Art Adams efforts to explore this at:
    https://provideocoalition.com/index.php/aadams/story/ex1_ex3_ir_filter_shoot_out/
    He concludes that the “hot mirror” filters might not be the best choice with this camera.
  • Dano Motley
    May 11, 2009 at 12:07 am
    just picked one up from b&h. looks ok in studio. will be putting it to the test this week.
    dano
