Activity Forums Adobe Premiere Pro IPS Monitors – 6 bit A-FRC Good Enough?
  • IPS Monitors – 6 bit A-FRC Good Enough?
    Posted by David Bitterman on June 25, 2012 at 2:48 pm
    I’ve been looking for reasonably affordable IPS Monitors in the $250-$400 price range. I’ve had a couple of video editors suggest the Dell UltraSharp U2312HM and the HP ZR2440w. The Dell is a little more in my budget, but doing further research I’ve found that they are both very similar (maybe actually identical LG panel?) 6 bit A-FRC panels that use frame/pixel averaging to achieve their colors. I’ve also found that it’s incredibly difficult to find any true 8-bit IPS panels in this range.
    Can anybody help me out and tell me if the 6 bit is still a good low budget monitor? I’ve heard the newer eIPS technologies have gotten much better with dealing with banding and other issues that may arise. Are there actually any 8 bit panels in my price range anyways? (hoping to spend a max of $300 for the monitors, though I would go a bit higher if necessary).
    Also, what are your opinions of 16:9 vs 16:10?
    Any and all help is much appreciated!
    Matthew Sonnenfeld replied 14 years, 2 months ago 3 Members · 2 Replies
  • Vinod Pan
    June 26, 2012 at 1:49 pm
    Hello David,
    I did my research too. I got U2410 recently but I am planning to return it due to heavy brightness. Leaving it, the only options in the budget range are U2312HM. True 8 bits are expensive and slowly getting replaced with LED back lighting.
    Only 24″ come in 16:10 – You may have to move your head hear and there. I felt it little big for my view. All 23″ come in 16:9. If you do more of layers and want to have the extra bit of a screen then 16:10 is the way to go.
    I would suggest to check it out for the size and go for it.
    Cheers
    Vinod
    Vinod
  • Matthew Sonnenfeld
    June 27, 2012 at 11:01 pm
    HP zr2440w. I have one and I love it. Honestly it looks very good, has a nice set of connections, and is easy to calibrate. You won’t be disappointed.
    Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 8GB RAM
    AJA IoXT
    Adobe Premiere Pro CS5.5, Final Cut Pro Studio 3, Avid Media Composer 3.5.4
    The College of William and Mary
