Activity Forums Adobe Premiere Pro iphone videos are causing nightmares
  • iphone videos are causing nightmares
    Posted by paul Bates on April 2, 2026 at 6:56 pm
    Help 🙁
    I’m on PC win 11 using premiere pro 2025.
    Iphone videos sent to me are giving me
    Frame substitution recursion attempt aborting after multiple attempts
    Error retrieving frame
    Videos look like they’re tearing / pixelated
    * It’s always the last half of the video.
    * I tried ingesting but media encoder keeps failing saying error retrieving frame
    * I tried handbrake to the videos in various formats, same issues
    * I don’t have gpu rendering i only have mercury
    I’m on a deadline and now I’m a day behind if not two. Please help.
    paul Bates replied 5 months, 2 weeks ago 3 Members · 3 Replies
  • Devrim Akteke
    April 2, 2026 at 7:49 pm
    If it doesn’t work in Premiere, Media Encoder won’t help either.
    Not sure if this helps, but you may try VLC to convert videos and then import those new videos into Premiere.
    April 2, 2026 at 8:04 pm
    Hey Paul,
    Last year I on PPro v2025 went through a project from hell, that might as well have been shot on an iPhone. A mixture of Windows 11 and NVidia did not help either.
    It would be really helpful if you could share the format of the video files that you are working with?
    Keep in mind that MP4 is only a “container” and that there might be more codec information behind it.
    Although, if iPhone source, you may be working with ProRes files.
    Also, what version of v2025 are you using?
    In recent years Adobe has thought it clever to release new versions of PPro, without proper testing, and I suspect in some instances knowingly with the knowledge that it is not stable.
    Is it all of your video files that is not working in Adobe Media Encoder?
    Is there another one that will load?
    If so, transcode to ProRes and see if that works?
    (Yes, I did read that you tried Handbrake).
    And, the difficult question: Has anyone actually seen your source videos playback without any problems with image or sound?
    If you have it, it might be worth putting it into Topaz Video AI?
    https://www.topazlabs.com/topaz-video
    WinX Video AI has a video conversion module:
    https://www.winxdvd.com/winxvideo-ai/convert-video.htm
    MyFormatConverter has from time to time helped me out as it does not think too much about the conversion:
    https://myformatconverter.com/en/
    I could go on, but some of these suggestions might help you.
  • paul Bates
    April 2, 2026 at 11:41 pm
    Hi everyone,
    I was able to find a solution after about 40 hours of searching the internet and arguing with chatgpt haha
    I used Handbrake to transcode the footage. The problem was the HDR Iphone uses. It could have also been the variable frame rate. In Handbrake I exported in h264 (lower quality sadly) , and set the color space to REC 709. And then lastly I set it to a constant frame rate. For one of the videos I had to do it twice for some reason.
    I had also had connectivity issues when downloading the original files so that may have cause some of the corruption. I downloaded the originals again, then transcoded in Handbrake. After that I right clicked on the footage in the project panel and selected – modify – interpret footate. And from there I double checked the color space and settings on the footage.
    I hope this helps someone!
