Activity › Forums › Boris FX Particle Illusion › .IP3 Project: How to Go from SD > HD Without Total Re-Do
  • .IP3 Project: How to Go from SD > HD Without Total Re-Do
    Posted by Philip Knight on September 12, 2009 at 4:53 pm
    Original project: SD 720×480
    New Working Size: HD 1440×1080
    Is there a way to in essence “zoom up” everything within the project, from particles to blockers, etc. to fit new desired HD format without having to start from scratch? Right now, all project elements are obviously too small in the new .ip3 since they were initially designed for its original, earlier SD or 720×480 size.
    Thanks.
    Philip Knight replied 17 years ago 2 Members · 2 Replies
  • Alan Lorence
    September 14, 2009 at 2:39 pm
    Yes. In the Action menu, choose “Scale Project”.
    Keep in mind that for best visual results with some emitters you may want to tweak the emitter a bit — just scaling it up doesn’t make it more HD-like. For instance, if you have a sparkle trail fairydust-style emitter at SD, when going to HD you probably don’t want bigger particles, you probably want more of them (to take advantage of the higher resolution).
    Alan.
    http://www.wondertouch.com
  • Philip Knight
    September 14, 2009 at 7:07 pm
    Thanks. That’s a relief, and your tweak note is duly noted.
