Activity Forums Apple Final Cut Pro Legacy Iomega Ultramax-Power Failure
  • Iomega Ultramax-Power Failure
    Posted by Luke Watson on January 31, 2011 at 1:35 pm
    I have an Ultramax Plus 2tb drive set to JBOD, which contains all my FCP capture scratch etc – the power socket on this unit is failing.
    I have an older Ultramax 1tb drive set to RAID 1, one (or both) of the drives are dying on this one.
    I’m thinking I can remove the drives from the unit with the power problem and put them into the older unit,
    but I need to know if it’s as simple as switching the older unit to JBOD prior to fitting the drives, and then turning it on,
    I don’t want to switch the RAID settings, plug the drives in,turn it on and find all my data gone!
    as always, any help much appreciated
    Luke Watson replied 15 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
