Activity › Forums › AJA Video Systems › IoLA and Kona 2 for no offset editing?
  • IoLA and Kona 2 for no offset editing?
    Posted by Matt Larson on June 20, 2005 at 3:07 pm
    I thought I read somewhere that if you have an IO and a Kona 2 you can set FCP to use the Kona 2 to get around the firewire frame offset delay that the IO has, even with SD video through the IO. Is this possible? I have a new Kona 2 coming today and I’ve always had to switch to Desktop Cinema mode for audio editing with the IO.
    Any suggestions would be appreciated, thanks-
    Gary Adcock replied 21 years, 3 months ago 2 Members · 2 Replies
  • Matt Larson
    June 20, 2005 at 3:33 pm
    I just checked my settings and I have frame offset set to 0 but when I use JKL to start stop playback I’m seeing about a 3 frame drift after I stop playback. Is this just an FCP issue?
  • Gary Adcock
    June 22, 2005 at 11:21 am
    < I >I just checked my settings and I have frame offset set to 0 but when I use JKL to start stop playback I’m seeing about a 3 frame drift after I stop playback. Is this just an FCP issue? < I/>
    you should not be at a 0 —frame offset the current offset for the current Io drivers is -3
    this frame delay is a function of FCP to allow for differences in cable length or router issues. it is not carved in stone.
    your results may vary ( or need to be modified)
    gary adcock
    Studio37
    HD and Film Consultation
