Activity › Forums › AJA Video Systems › IOHD to SD Switcher to Jumbotron
  • IOHD to SD Switcher to Jumbotron
    Posted by Jeff Mack on April 18, 2011 at 8:40 pm
    Hello all, I got this gig to run media to a jumbo tron at a music festival next week. In between acts, I will play off my FCP timeline, artists videos with audio. The switcher will then send my image to the jumbotron. I don’t have the model of the switcher yet but I will post later on. The jumbotron is 17 feet by 13 feet. I am trying to get the specs on it as well, pixel aspect ratio etc. My thought was to have a rendered motion background with the video inserted with some graphics.
    Any suggestions of what I should be looking at doing? I am at the event on Sunday and the JT goes live Tuesday afternoon.
    Jeff
    Jeff Mack replied 15 years, 5 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    April 18, 2011 at 9:59 pm
    If it’s an Sd switcher, I’d imagine you should work in an Sd ProRes timeline, 720×486. Those measurements are roughly 4×3.
    Jeremy
  • Jeff Mack
    April 18, 2011 at 10:15 pm
    Hi Jeremy, I was going to do that for the media I was going to show but I was thinking of a layer beneath the media like a simple motion background that would fill the 17′ x 13′ screen. I don’t want to blow out the videos but having the background layer there would allow me for some text and such. Does this make sense?
    Jeff
  • Jeremy Garchow
    April 18, 2011 at 10:17 pm
    [Jeff Mack] “Hi Jeremy, I was going to do that for the media I was going to show but I was thinking of a layer beneath the media like a simple motion background that would fill the 17′ x 13′ screen. “
    Hey, Jeff!
    17×13 might be the physical size of the screen itself, and not the aspect ratio of the actual diplayed pixels.
    My guess is that all they will need is 4×3 Sd image, you can choose to fill it up how ever you choose.
    Let us know once you get the specs.
    Jeremy
  • Jeff Mack
    April 18, 2011 at 10:24 pm
    Yes, 14 x 13 is the physical size. I am waiting for the par and sar for viewing. Since the 4×3 video would leave a lot on the sides, I was going to add the background so it was more pleasing than black. I just didn’t know how to handle that in FCP. I realize I could set up a 16 x 9 sequence with it being filled with a background and then lay the sd Pro Res file on it, add text and render out to play a 16×9 .mov through the IOHD and into the switcher. Im sure it is an SD switcher so I guess I can only letterbox or crop. I’ll let you know when I get the specs.
    Jeff
