Activity Forums AJA Video Systems ioHD input from DVD via HDMI
  • ioHD input from DVD via HDMI
    Posted by James Dow on July 16, 2009 at 9:11 pm
    I want to import footage into FCP using an ioHD and a DVD player with HDMI output. I have the DVD player connected to the ioHD, with the HDMI input selected. The ioHD control panel is telling me that the HDMI input is not detecting video. It flashes between 1080i29.97 and no video. Any suggestions as to what I should do?
    JPD
    Ged Yeates replied 17 years, 1 month ago 5 Members · 10 Replies
  • 10 Replies
  • Jeremy Garchow
    July 16, 2009 at 9:43 pm
    Hit play?
  • Gary Adcock
    July 16, 2009 at 11:17 pm
    [James Dow] “Any suggestions as to what I should do? “
    Stop.
    you have tried to copy a DVD and the HDCP security is blocking the capture over the HDMI port.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • James Dow
    July 17, 2009 at 12:25 pm
    I did push play.
    In regards to the security protection, the DVD that I want to import contained segments from TV newscasts and a clip from the Daily Show. It was produced for internal corporate use, and no encryption was used on the DVD master. Does this still sound like the HDCP security blocking?
    io Newbie
    JPD
  • James Dow
    July 17, 2009 at 12:30 pm
    Also just trying capturing a DVD that I produced, with no encryption, and it’s doing the same thing. Bad HDMI cable?
    JPD
  • Gary Adcock
    July 17, 2009 at 12:41 pm
    [James Dow] “Also just trying capturing a DVD that I produced, with no encryption, and it’s doing the same thing. “
    you are incorrectly assuming that the encryption is on the disc
    It is the 2 devices talking to each other over HDMI.
    you can try changing the cable, but I doubt it will solve the issue.
    gary adcock
    Studio37
    Check out
  • James Dow
    July 17, 2009 at 2:08 pm
    So if it’s the 2 devices talking to each other via HDMI, with this particular deck, will I be able to import anything from DVD? What’s my workaround?
    Thanks for your time.
    JPD
  • Jeremy Garchow
    July 17, 2009 at 3:17 pm
    [James Dow] “What’s my workaround? “
    Try analog.
  • James Dow
    July 17, 2009 at 6:44 pm
    Yeah, that was next on my list if I couldn’t get the HDMI to work.
    JPD
  • Todd Reid
    July 28, 2009 at 3:27 pm
    going analog is going to be your only option.
    I needed to get some (non-copyrighted) material off of a dvd, (for legit purposes), and ran into same thing.
    Tech support at AJA taught me that it should NOT work ever, by design, to help control piracy. He said your only option was to go in component, which I did, and it worked perfectly. He told me its hardware built into the dvd players, as well as the encryption put on the discs themselves, therefore it doesn’t work regardless of what kind of protection is on the disc, including none.
    Todd Reid
    Senior Editor
    Digitized Media, Inc.
  • Ged Yeates
    August 3, 2009 at 12:45 pm
    Hello
    Another workaround is to ‘move sideways’ so to speak and employ software such as ‘MPEG Streamclip’ which allows you to take video files directly from a DVD and output them to the codec of your choice (in this case I’m assuming you want Apple ProRes422).
    If the DVD is commercial or copy protected this solution will not usually work but ‘internally’ produced DVD’s or client supplied DVD’s should work fine. It’s a method I’ve used several times and saves all the interface headaches of HDMI and going analogue and is done transcodes than real time.
    The video quality is of course limited by the encode quality of the DVD so it looks pretty similar to capturing through a video input (digital or analogue).
    MPEG Stream Clip can be downloaded of the Web. There are other software alternatives available as well but I mention this one as I find it works hassle free for my own workflow needs.
    Bye – Ged Yeates (Scotland).
    Ged Yeates – Lighting Cameraman
