Activity › Forums › AJA Video Systems › IOHD Echo Issue
IOHD Echo Issue
Posted by Javier Escobar on February 26, 2008 at 5:56 pmHey guys, I upgraded to newest AJA IoHD 5.1.1. It resolved my audio blackout issue. However now after editing for a couple of hours, I start getting this echo effect. It’s like the audio repeats itself every half a second or so.
Only a system restart fixes it. A FCP update doesn’t do the trick.
OSX 10.4.11
2x 3 GHZ Quad-Core Xeon
8GB 667 MHZ DDR2 RAMAny hints?
Javier
Javier Escobar
Paul Huppe replied 18 years, 6 months ago 5 Members · 9 Replies -
Kevin Gardam
February 27, 2008 at 12:35 pmHi Javier,
I’m having the same issues as yourself and I have the same spec as yourself. Aja support are aware of this as I contacted them yesterday.
I throw away fcp prefs and that sorts the issue but I don’t know for how long.
Hopefully there will be an answer soon.I’ll keep you posted
if theres a cure.Kev
Kevin Gardam
February 27, 2008 at 1:11 pmA further point, I can create this echo fx by bringing up the sound prefs whilst in FCP or soundtrack. Closing the prefs
seems to clear the problem so it seems the sound prefs are corrupting or something. So if you bring up the prefs and close them down again, should keep pushing the problem away til aja
resolve it.
Kev -
Forrest Burger
February 27, 2008 at 4:30 pmI’ve had this issue as well. What I do is click on another clip in the sequence that has audio, play that for a second, then go back to the clip that had the echo and it seems to stop.
Forrest
Kevin Gardam
February 27, 2008 at 5:26 pmOh I wish my issue was as well behaved. Can take a bit of messing around to get rid off.
I look forward to what Aja make of it. -
Paul Huppe
February 28, 2008 at 8:49 pmJavier, I’ve also ben having audio blackout issues and they’re still unresolved.
How did you take care of the problem?
Paul -
Tim Allison
February 29, 2008 at 2:49 pmDid you download and install the new AJA 5.1.1 software update? The old version was simply 5.1 software. When I put the new version on, I also had to update the firmware.
Kevin Gardam
March 3, 2008 at 4:47 pmIf you select sound prefs-output and instead of having aja io
put internal speakers, this appears to stop the echo.
Not obvious I know as you would expect o/p to be iohd, so the iohd must be live regardless of o/p in sound prefs.
Hope this helps…and wasn’t in the manual! -
Javier Escobar
March 3, 2008 at 8:29 pmToday I have been Echo-free but hoping for a more stable fix.
THX, I’m glad to know I’m not the only oneJavier Escobar
Paul Huppe
March 7, 2008 at 7:25 pmI think I’m finally free of my audio blackout issue after updating to 5.1.1 (knock on wood)
WooHoo!
Paul
