Activity Forums AJA Video Systems Io4k – audio playback problems – bad compression
  • Io4k – audio playback problems – bad compression
    Posted by Jimmy Brunger on September 17, 2015 at 11:40 am
    Has anyone had any issues with using the headphone output on the front of the Io4k for audio monitoring where music sounds like its been mastered within an inch of its life? I.E: when it gets pushed to hard and you get pulsing of instruments coming in and out as their headroom gets swallowed up?
    I’ve listened to the same track in PremierePro just through my Mac Pro’s audio output and the same headphones and sounds fine.
    It’s like the Io is ‘legalising’ the audio it pushes through it. I can’t see anything obvious in the configs to remedy it.
    Any ideas guys?
    James
    Adobe CC 2015
    MacPro 2013 8-core 3GHz / 64GB RAM / Dual FirePro D500s / OSX 10.10
    AJA Io4k / 2TB SSD RAID-0 local scratch / SNS EVO on 10GbE
    Jimmy Brunger replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
